Ecu checks for low oil pressure
Burt
Hi,
I’m getting a low oil pressure code P0524. I have triple checked and changed all the usual suspects-
Oil/ oil level
oil filter
Oil pressure switch.
I have put a manual gauge on to watch my pressure while running and it is within spec, so I am confident I have oil pressure.
I have checked the wire from the pressure switch to the ecu with a meter and can not find any breaks in the wire.
This leaves me to think the issue is with the ecu. Is there anyway to diagnose the ecu?
I can unplug the oil sensor and run, but I have the check engine light on which is not ideal. When I have the pressure switch plugged in, it goes into limp mode after a few minutes and gives me the low oil pressure code.
any help would be much appreciated!
Thanks
I had a stubborn low oil pressure warning last year. Replaced the OPS and the problem persisted.
Finally took it to the dealer.
Apparently, there was a small O ring on the OPS that I had missed.
That missing O ring didn't allow for a proper seal and caused the ECU to trigger a low oil pressure alert.
