Shane0524
I just rebuilt my carbs and put them on the boat,,, it didn't run right and was flooding when stopped. So i pulled the carbs and found one of the hinge rods from the needle arm was not in its slot correctly and was causing a low pop-off and some leakage. I also decided to do a pressure test with about 20 psi, the pto carb holds fine but the fuel pump mag carb has a hissing noise and it leaks out of the back hose hole on the fuel pump. when i cover that with a finger its quieter but it still hisses from somewhere. is this a problem or is this normal
