Angie Active Member Aug 6, 2018 #1 Only found one fuse and changed it. New battery still nothing. Put new starter solenoid on still nothing!
G greenhornet2 Active Member Aug 6, 2018 #2 maybe a post or key issue. I would check connectors first for corrosion. What year make model? This is in the sea doo spark section
mikidymac Moderator Staff member Moderator Aug 7, 2018 #3 Typically this fries the MPEM computer when the cables are hooked up backwards. This would also explain why it is completely dead.
T TimJCarrow New Member Aug 28, 2018 #4 Angie said: Only found one fuse and changed it. New battery still nothing. Put new starter solenoid on still nothing! Click to expand... You may also want to check starter motor and the key. If you hear clicking when you are trying to start it, the problem is 99% in the starter relay.
