will this work?
not2high2fly
I have a 94 gtx/657cc/sbn 38 mikuni carbs and my question's are about the carbs and the fuel lines. The set up I have now is fuel line in to mag /out of mag to in on pto /out of pto back to tank is this correct? With the lines off I can blow/suck air through the mag carb by attaching a short line to the in / out nipple, should I be able to do the same on the pto carb? I also just picked up a used set of carbs to rebuild and install and they are totally different. The new carb set up is two mag carbs(pto has fuel pump and pulse nipple) and his fuel lines are as follows the single fuel line split's with a Y connector to both in nipples on both carbs, both carbs out nipples Y together and the single line return's to the tank. So no line connects the carbs. From the pic's (haven't received the carbs yet) you can't see the pulse lines but I guess they have a Y also to a single line to the engine. Will a two pump(two mag carb) set up work? Thanks for the help
will this work
Am I explaining this correctly ? I thought it was going to be an easy question
