What ski do you recommend buying. I have a 96 gtx and want to upgrade.
tjc702
The problem is that the 96 gtx is a fun ski to ride. It spins out and very nimble. Is there a 4 tech that has that same fun factor?
The only small 4-tec that you can throw around is the Spark. The spark is the modern equivalent to the old XPs for example.
The 4-tec GTX is HUGE by comparison. Rides like a Caddy, but you can't "throw" it around.
If you get an RXT-X or RXP, they are so strong you can use the jet to "throw" it around.
Wish those latter two would weigh less... I've always wanted to stuff a 255 4tec into an xpl...
Here is the ideal low maintenance fun combo. Get a GTI 130 1.5 l . Fill all the ride plate and intake grate holes cuz that will take a pwc that already likes to spin and make it better. Get a V Tech tune but instead of upgrading to a 11/19 impeller like I did , stick with the stock size so that you will be using the boost in torque by the tune for snap acceleration instead of top speed that will still be a bit higher then stock .
If you want ultimate throw around, get a Spark. If you want the power to pull a couple of tubes behind you and then, once disconnected, throw yourself and the ski around, get a GTR 215. I can do flat spins, ride the ass end, jump the hell out of some wakes/waves and get from 0-60 in under 7 seconds.
Yes, a S/C ski requires more maintenance. But I'm out there to have FUN. Not to worry about spending $400 every two years on a S/C rebuild. On my GTR215, I can trim it all the way down and walk on water as I lean back. I've made it dive, do 60° turns with the impeller partially out of the water, down hard, deep spins that inundate the ski with water, so on and so forth. For sure, the Spark is a lot more "throw-able", but then it can't pull a 250lb man up on ski's either. Nor can it tow two tubes with 500lbs each on them. I also use my ski to go out into the Gulf to fish. Or fish inland waterways. IMHO, the GTR215 is the most stable do-it-all platform out there. But it's up to you. Hit up Youtube and see which ski does what YOU want to do. Don't listen to just us.
