What do you use to block off grommet at oil tank...
ChrisV
What do you use to block off grommet at oil tank when switching to premix???
My oil inj line is 5/16", can you use a vacuum plug or with the oil break it down.
Even when pre-mixing, you still need the two big lines going to the engine. They lube the crank case.
Just in case you were talking about those.
Why not just clean out the OEM oiling system so it uses the variable rate injection to prevent plug fouling, save a few insects and a lot of oil money? Prolly just got gel from mixing oil types, the old owner never gave you the oil bottle?
cut the one line short(return line) remove the (send line)and short loop the return line back into where you removed the send line
