betadeltadelta
New here and new to SeaDoo’s.
I recently picked up 2-2005 GTX S/C’s and one has 5-10 psi of oil pressure measured at the oil pressure sensor bung.
I stripped the ski down tonight in the rear, including the SC and water pump cover to check out the rear oil pump and oil pressure regulator etc. All PTO bolts are removed and the bearing/boot is removed too. I also jacked the engine up 1.5” on the left motor mount to get the two bolts directly under the drive shaft/thru hill area.
I can slide the PTO cover off close to half an inch and can’t seem to get it any further. If I let go it seems to “spring” back. Is the the magnetic stator sucking it back into place? It almost seems like a rubber boot or something similar that is making it spring back onto the engine.
I know there is the bendix, but I don’t think that would “suck” the PTO cover back on. What am I missing? I don’t want to make my life any worse right now after wrestling this thing apart tonight.
All of the videos I’ve watched including the very detailed ones from 3FT Deep, there doesn’t appear to be anything internally that would make it hang like this.
Thanks in advance!!
Thanks in advance!!
