We now sell all 2-Stroke WSM Parts
hfgreg
Administrator
Staff member
ADMINISTRATOR
Messages
3,130
Likes
42
Location
Tampa, Fl
#1
Hey guys, just letting you all know that we sell all WSM parts including carburetors, impellers, top end rebuild kits and more. Just PM me with what you need and we will give you any WSM part at 10-15% off. We hope to have many of the parts listed on PWC Muscle in the near future!
hfgreg
Administrator
Staff member
ADMINISTRATOR
Messages
3,130
Likes
42
Location
Tampa, Fl
#3
A couple years later and we are still adding away. Please post a part in this thread if you want it added to PWCMuscle.com and we will get it posted right away!
Dr Honda
Moderator
Staff member
Moderator
Messages
19,193
Likes
498
Location
Pittsburgh
Water Crafts
'00 Polaris Genesis
'96 XP800
'02 Islandia 240 EFI
#4
Hey...
did you get the mercury rebuild kits too?? The WSM Merc parts are really very good. Mine is 3 years old now, and runs like a champ. (in the Islandia)
If you did... we may want to make a sticky in the Merc section.
hfgreg
Administrator
Staff member
ADMINISTRATOR
Messages
3,130
Likes
42
Location
Tampa, Fl
#5
Tony,
We can get any WSM part at this point. We just don't have the time to list everything yet.
:cheers:
Dr Honda
Moderator
Staff member
Moderator
Messages
19,193
Likes
498
Location
Pittsburgh
Water Crafts
'00 Polaris Genesis
'96 XP800
#6
Tony,
:cheers:
When you get a chance....
Figure out what the "Kit" will cost for the 240 EFI, 210, and 200 Opti. (Pistons, rings, wrist pin bearings/pins, rod bearings, rod bolts, crank bearings, and gaskets) I'm sure we want to direct orders like that you you, opposed to the eBay guys.
glsmohio
Messages
1,984
Likes
15
Location
ohio
Water Crafts
(2) 1996 xp , 1996 spx ,1997 spx. 1997 GS, 1994 spx, 1994 xp, 2000 xpl
#8
whats the going rate for a top end for a 787
Messages
88
Likes
0
Location
Arizona
Water Crafts
2000 XP & 2003 XP DI
#11
WSM parts
FYI: you probably already know this but the WSM balance shaft parts for Sea Doo 951 DI shows two seals needed when you need THREE. The compressor kit does NOT have the crank bolt required, the disks and a couple of seals. Thanks!
etemplet
Premium Member
Premium Member
Messages
1,972
Likes
143
Location
Louisiana
Water Crafts
1996 SPI, 1996 GTX, 1997 GTX
#13
I have a 1997 GTX. with a damaged cylinder. I need a top end kit for it and also whatever I need to rebuild the bottom. Question... What is the Max bore size for a 1mm cylinder? I am ready to order. Do you have the parts??
JoeZ
Administrator
Staff member
ADMINISTRATOR
Messages
2,159
Likes
31
Location
Tampa
#14
@etemplet Hey Gene, what do you mean by max bore size for 1mm cylinder? Are you referring to how large you bore out the jug for using a +1mm?
We can get all the rest and should all be in stock.
etemplet
Premium Member
Premium Member
Messages
1,972
Likes
143
Location
Louisiana
Water Crafts
#15
I am trying to get at max bore size on the cylinder to determine if mine is within tolerance for installing the pistons and rings. I think I am on the upper limit. I'm guessing about .005" clearance for the piston. I have two cylinders I need to bore one. If I can get way with the current bore on one and rebore the other Genie will be happy. :) Do I get a discount being a forum member? I will call Monday to discuss parts. Do you have Mikuni diaphrams for the carbs??
Napayne91
Messages
3
Likes
0
Water Crafts
1997 gti sea doo
#17
How about fuel baffel
Users who viewed this discussion (Total:1)
SPONSORED LINKS
Usergroup
