Hi -
I bought a 2001 GTS with a 718cc silver engine for the hull but the engine seems to be OK so I try to fix it. The cynliders was full of water. I crank the engine with the plugs out to get the water out. I crank it with low duty cycle, crank for 5-10 seconds and wait for 2-3 minutes, the starter seem very cool. I spayed WD40 into the plug hole every few crank cycles. I put a leaf blower on to the plug hole creating some pressure and lots of water coming out at the pump area some where!! is this normal or OK?
Anyway, I think the water is out of the engine, no water droplet flying out of the hole anymore. I put the plugs back and the starter could not turn the engine. I have a good battery connect directly to the starter bypassing the starter relay and it still can't crank. I think the starter may be bad but want to make sure before pulling it out. Is there a other way you can tell if the starter is bad? I saw some posts saying you can pull the starter with a 13mm long extention but is it possible for this particular engine? Also, how long can I leave the egine like this before the croision kill it completely?
Thanks for all the help.
