ondagaskiknass
So i bought a 1997 Seadoo challenger on Sunday and it is my first boat ever... Hurrayy!!!!! When i got there the guy connected the hose and started it up and it ran just fine.
I took it out yesterday and the boat was very boggy and within a minute of putting it in the water, water was leaking into the boat from the drain underneath the drivers seat. After some research it sounds like i need a new Scupper. Just ordered one and fingers crossed that's fixed.
I decided to start the boat and verify it started and it did but would cut out as soon as I tried upping the RPS's and it was boggy while in lower RPM's. After i got the boat home I noticed there was no cover over the flush connector. Should there be? Water would flow in just like a hose if there isn't correct?
Either way, If i flooded the block or the person i bought it from did, i took out the plugs and turned over the engine. I got out as much water as i could. I used Carb Cleaner in the valves to help dry it out. I did put some WD-40 in the valves as well hoping to stop any rusting that might occur overnight. I did not have a hose at my house yesterday and very limited resources so I'm going to stop on my way home today and pick up some stuff.
Overall Questions:
Is there anything else i should check with the drain?
Do i need to have the flush hole plugged when taking the boat out on the water? As far as i can see, the only 2 holes i need to plug were the 2 drain plugs.
Any suggestions of anything else i should be doing to help get water out of the engine?
Thank you for any help! It is much appreciated!
Overall Questions:
