jimmaki
The VTS on my 98 SPX just quit working. When I press the up or down button, all I hear is a click coming from the VTS module. I opened the VTS oval motor box and found a lot of water corrosion inside. I disconnected the motor leads and jumped them straight to the battery and the motor appears to be working in both directions. So from what I gather the switches are working, the relay is working, and the motor works when connected directly to the motor. I assume the fuse is ok because of the clicking relay. I can't tell from the schematic if the fuse protects just the motor or all the power to the VTS module/motor.
If the motor is working is there benefit to taking it apart while I have it out? The round cover over the worm gear appears to be a metal cover that is crimped on. Not sure how to get it off and then how to secure it back on.
I'm thinking of drilling a hole in the bottom of the case to let water OUT as the box obviously isn't as sealed as the gasket and boot should appear to make it.
