Seadoo1996
Hi im new to owning a seadoo I recently bought a seadoo challenger 1996 it has the oil plate blockoff and was wondering what oil ratio should be.
Hi and welcome to the SeaDoo Forum.
You should use a 40:1 mix ratio. Use a API-TC rated oil, I believe you have a 787 with rave valves, so you should use a full synthetic oil.
Lou
YOU SOUND LIKE ME SIR? LOL, ok from what I read on here and by most experts on here, is 40:1 ratio is 3.2 ounces of oil for every gallon of gasoline. So 10 gallons get 32 ounces of oil. Since my boat is only a 85hp 657x motor, I only use about 3 gallons of gasoline a day (if that), so I put in 9.6 ounces of oil for the 3 gallons of gasoline.
Good luck
Are you saying you only put 3 gallons of gas into your boat at a time? The way you are adding gas and mixing the oil could have something to do with why your boat continues to have problems. You really need to add more gas and add the right amount of oil accordingly. If you only put a few gallons of gas at a time in there, you are probably sucking up crud on the bottom of the tank.
It really isnt about just fouling plugs and gummin up the carbs. It is effecting how the boat runs. Trust me, you will probably notice a difference how it runs. You only need to premix or use the injection system, not both. The sparks plugs are constantly trying to burn gas that has too much oil in it. Does your boat smoke a lot?
