I bought this ski running very poorly...
i cleaned out the carbs and adjusted them, making sure that i didn't run into a lean condition.
(if anything...it may have been running slightly rich at low speeds or idle)
The ski was used for about 3 days without any issues (occasional bog while trying to accelerate after idling for 20min)
4th day...someone other than me was using the ski...broke down and came in with SeaTow(best $125 bucks ever spent)
Here is the story:
-first they ran out of gas
-seatow brought 5gallons out to them
-Ski started and they got to gas station and filled up
-Ski stopped again after running for a while
-from what they described...motor seized up
...they said that they hit starter, but acted as though it was a dead battery.
-Seatow brought ski back to the dock
I looked at ski when i got it home...it would crank but wouldnt run...i pulled the plugs and they were very wet
I pulled the fuel filter and found dirt in the bottom and the mesh insert had come free from its mount allowing dirt to be able to get to the carbs.
left both plugs out and cranked motor...seemed as though mag carb was dumping fuel into motor
I turned fuel valve off and eventually got the motor to fire (i think this happened once the carbs stopped dumping fuel into motor)
Checked compression for the heck of it (i had never checked compression on this machine before)
got 100 on the pto cylinder
got 135 on mag cylinder
NOW WHAT...that seems pretty bad...not sure if this is always what the compression was...ski did about 40mph after the carbs were cleaned out.
I can clean the carbs again, but what do i do about the compression? I am scared that i need a motor.
Any help would be greatly appreciated...you guys have been great so far.
95 Seadoo explorer
2 stroke
Dual carbs
657
Lou...i didnt stay in a Holiday Inn Express last night...thats why i need your help
Here is the story:
95 Seadoo explorer
2 stroke
Dual carbs
657
