hello all. New to the site and new to Seadoo challenger ownership. Own a 2011 210 Challeneger sp. boats been awesome so far but last time out one engine (starboard) had an issue. While ramping up rpm the starboard engine acts like its choking out above 5000 or so Rpm then take it to idle and it runs rough and eventually dies. Let it sit a while and starts right up and runs great up to about 4500 rpm or so, but if I go wot or push it past 4500 rpm or so it repeats the issue. My first thoughts are spark or fuel issues. The engine starts right up (when not preceded by the issue) both in and out of water and idles and runs fine. Only has issue when trying to get to higher rpms. This just started happening out of now where while we were on the lake wakeboarding (new and thus lots of wot to stop to wot). Ran great before. I replaced the spark plugs and swapped the coil packs from port to starboard and that didn't fix anything. While troubleshooting I noticed water spray inside engine compartment and on the right hand side of the stbd engine (the one with the problem)(facing aft) there is a 2 large pipes joined by rubber hose and clamps that is spraying water. I'm not sure if that is related or a separate issue. Any advice would be greatly appreciated. I am thinking about checking fuel lines / filters? But not sure how to do that.
