TRIM PROBLEMS please help
nb717
i'm having nothing but problems with my VTS unit. Last summer it died out. after it sitting over the winter, and changing the fuse, it seems to be working now. the issue is i can move the trim all the way to the bottom, and the gauge shows its bottomed out, but when i move it all the way to the top, it stops half way, and the gauge does too. When i take it out on the water, i cant get the trim to move at all. Ive taken it all apart, cleaned and regreased the screw, and tested the motor, and nothing seems to be obvious.
should i just find a new VTS unit?
that doesnt sound like its an easy fix... any suggestions what i should do? i used my trim alot when it worked, because where i ride the water conditions change quite a bit
