Throttle body change out
oleman77
Ok guys, just getting to the throttle body issue. Did find a good used throttle body and have had it check by dealer. They said it checked out fine. Now just have to install it. I have no idea where to start but I'm am mechanically inclined so I'm diving in. Has anyone changed out a throttle body before? If so I could use some help. Or does anyone know of a thread that show the steps I need to follow? I looked but did not see anything on it. Thanks guys....pete
The throttle body on a Di engine rarely go bad. So... I doubt there is a thread here on it. But the procedure should be int he factory service manual.
Really it should be straight forward... but the TPS probably needs calibrated, and you will definitely need the manual for those specs.
Ok got the TB changed out. Was a bit difficult but not too bad. I called the Seadoo shop and they told me to try to see how it runs. If it runs a little rough I will have to go and get it sync'd and calibrated. Thanks for the reply.....
