Danosll
okay so ive broken 3 rave valves on the same cyl. in the past year(both oem and SBT). 2 at shaft 1 blade in half. have changed valve housings and soft parts. but the problem is in the actual guillotine bore itself. . stock bore piston +rings and cylinder are in great shape View attachment 32054 compression is 150+..i thought about having it welded, too hard to reach and too thin. thought maybe high temp jb weld or devcon. now i leaning on a replacement cyl and if possible pressing good sleeve out of my bad cyl and pressing it into a good used cyl. that way i can salvage my piston, possibly even my rings. anybody have any suggestions . im open to any ideas
