I need help FAST. I am new to these machines and my 1998 GTX Limited took on a lot of water the last couple times I used it. Last time, I just drained it. This weekend, I used it on a couple short runs and it was OK. However, today when I took it out, it took on a lot of water (few inches, maybe more) and it got sluggish, ran at about 3,000 rpm 10-20 mph max. I got it back to shore and found all this water.... I immediately got it on the trailer and drained all the water out. When I got home, I thought I'd put some water in the bottom of the ski and see if I found it leaking out somewhere.... nothing. Instead, while looking in the engine compartment, I found the Tuned Pipe missing 1 bolt, other two bolts about to fall out, tuned pipe flange hole broken out and the gasket in a few loose pieces. Now, I'm assuming the water was being pulled in and dumped past this gasket.
#1: What do I need to do immmediately to keep from engine being ruined.
#2: How difficult is a replacement/repair for the tuned pipe?
#3: What should I do to make sure everything is back to 'normal'?
Please help. I have to travel all week, so if I need to get it to a dealer ASAP, I will. Otherwise, I'll try to do the repairs myself. Thanks
