I have noticed that I have lost some speed in my Challenger 430, so thinking that it was time to take super chargers out for a rebuild and I found something I think could be really bad. Need a second opinion or more from people that know more than me. I took both super chargers t and found out they were different. Starboard side had a gear on it and port side did not. I took photos below and you can see that there is definitely a difference. I also found that the oil on port side is a bit milky. Showing that there is water in the oil. I have not had any problems with over heating or excess use of oil or coolant. I'm thinking this must of just happened. The question is can I drain the oil and replace with new, replace rebuilt super chargers and see what happens or should I tear down the engine. The problem is I do not know where the water came from and if there are gear parts floating around. I need some advice!
