Seadoo 3D?
I'm sure you already know how a search engine works. It's based on the info stored from previous posts. Well, there really isn't many users in the forum with the 3D. Those that are, come in for the same problem. They tip to the right. But all search engines I've ever used needed more than 2 characters to work....
I have tried to research this and have really found no luck. The results are pretty much the same, if the ski isn't leaning while it's sitting at dock, it shouldn't lean while underway. There are a couple that have been in, that have not had this problem.
At first, you want to point at the propulsion unit (jet) set up. Thinking of the possible torque causing it to lean.....but that seems it would affect all, not just a few.
Then, maybe it's the weight displacment.....but it seems that the few I've corresponded with, all have different weights and loaded the ski differently.
So, it brings me to the seating.
I haven't asked this specific question yet but because the ski has two different riding positions, does it ride the same on both positions?:cheers:
