Hi,
I have a Utopia 205, year 2003.
The motor is a Mercury Optimax 200 M2 JetDrive.
When cruising on water with a fare amount of people (max 8) and equipment store everywhere, all is fine.
BUT when pulling a tube with a adult (175 lbs) after several minute, the motor stall/choke.
Then I'm unable to restart it right away. I need to wait about 5/10 minutes and crank the motor up by turning the key....and at some point it will restart.
This is happening each time I have a tube attach behind and ONLY when the tube is attach.
NO tube = smooth sailing.
WITH tube = motor stalling/chocking.
The dealer didn't found any error code from the motor.
Everything look fine from "his" point of view.
I've change all the spark plug, the injector are all clean and working fine.
The propeller and the ring are all clean and new. (rebuild)
I'm out of ideas.
Anything is welcome. If you need more info, please let me know.
Thanks in advance,
Frank.
I'm out of ideas.
Thanks in advance,
Frank.
