yep- if that engine is running, then the impeller should be turning all the time- it's a direct connection to the crankshaft via the output sleeve. if the engine is running and impellor isn't spinning (no forward movement) then there's an issue with the drive shaft splines- my guess is the splines on the "softer" shaft somehow broke / stripped. can't imagine how it happened, but getting a lot of air jumping wakes could cause the impeller to "shock" the driveshaft when there's suddenly no water (friction) going through the pump. that's why I always release the throttle just as I jump a wake and the pump is out of the water- otherwise, as the ski comes back into the water, it puts a ton of stress on the driveshaft as a high rpm impeller hits the water and starts pushing it out the nozzle again- that's not good. Since I'm directly on the lake in big cove out of the main area, ski's always use our cove to play in and I always hear skis jumping wakes with their throttles pinned while in the air- I just cringe.
