On the rear of the seadoo is the spedo gear. It has 2 or 3 wires coming off it inside the hull of the doo. Using a multi meter between 2 of the 3 wires you should get resistance as the small wheel spins, indicating the sensor is good . You only need 2 wires but if it has 3 wires the 3rd wire is for a temp sensor on some models. If you get no resistance from the spinning wheel then the sensor is bad. The gauge is not able to be checked, or repaired as it is a sealed unit.
Karl
