So I tore down an SBT 951 from a 99 GTX limited today. Unfortunately, when I quit working at a SeaDoo dealership, it was 1997 and I had only serviced one 951 and it was on a GSXL. Never tore the engine down.
In that time, I had never seen any sealants used on the surface between cylinder and case. Only the Loctite 515 between the case halves. Which as I understand it is no longer used and it appears that folks are using 3 Bond 1211.
Is this something new? It would seem that sealant could cause a squish issue. I I haven't looked at the original service manual yet, but I would like to know if this is recommended in that application because I will be building a 951 soon. If it calls for that, fine, but I have never done it. In fact, the 787,717,657 and 587 all were dry and also had bolts to fasten the cylinder to the case, where the 951 uses the studs through the cylinder and is secured by the head.
I would like to hear from either Dr. H, LouDoo or Minnetonka4me on this one, but if anyone knows for sure, I would like it cleared up. This engine has been running for 3 years that I know of and just ingested water this week, but appears to possibly have an air leak which is why this engine is apart in the first place.
