Hi, I have recently bought my seadoo xp 97. I have an oil leak from the bottom end of the engine block. All my 2stroke oil is leaking into the bottom of the hull. When I use the ski it barely leaks as its flowing but standing still it drains a full tanks in 2/3 days. I found roughly Where its coming out and it seems to be the crack gasket. I dont know much about engines though so I have not taken it apart to see properly. The only things I can think is the gasket or the crank case is cracked. I'm after feed back on what is the most likely cause for the leak and on a scale of 1-10 how easy is changing the gasket?
Thanks
Thanks
