shanemccudden
Hi,
I have a SEA DOO with a black hull with some damage I am trying to restore. It was caused as you can see by the rubber on the front of the trailer missing, and a bolt been exposed touching against the hull. Was debating just painting with standard paint or should I use black ultra strong gelcoat? Would that increase the strength?. Also can this be applied via a spray gun or what would you advise.
The hull itself has a hole in it (Pic Attached ). Its not completely through the hull but not far away but there is enough fibre left to build upon. My body man thinks the best course of action is to fill this with (green) pre mix fibreglass that you ad the filler to. Will this be strong enough and not crack etc?
Any expert advise for the matter .... Thanks
