donaldjboyer
Hi all,
Seadoo GSX 1997
110 hours
I have had an issue over the last few months where I'll install brand new spark plugs in this machine and it'll run fine for approx 1 hour and then start running rougher and rougher over a few minutes until it'll barely run. The only remedy is to install brand new spark plugs again (which only last for an hour). And in a recent run, the 'check engine' light came on the dash briefly also.
I have cleaned the carbs, fresh fuel, new battery (fully charged). When I have checked the voltage at the battery (while running on the garden hose) the voltage jumped around quite a lot, but the display refresh on the digital multimeter was slow which made it difficult to see what was going on.
I am thinking the voltage regulator might be at fault, but could you please help me by suggesting what I should look at diagnosing? (trim spark plug lead ends? check negative cable from battery to engine etc).
Thanks in advance,
Donald.
Seadoo GSX 1997
110 hours
Thanks in advance,
Donald.
