So after extensive searching, I finally came across a trim tab that was manufactured specifically for the Sea-Doo. It is a mechanical trim tab that is fixed to the ride plates. I've found numerous pictures of the tabs, and even some discussion on this forum as well as on Green Hulk. I can even find a part number online, #295-500-986, but internet searches for it also reveal that this part has been discontinued. Sooooo.... in the quest to stop the porpoising....I would like to build a set of these trim tabs, but cannot find any specific dimensions to go by. I found a Facebook entry that gave a clue....looks like it's a 3" extension of the ride plates and has a total of a 1/4" deflection adjustment. Looks to be either 3/8" or 1/2" thick. But that seems to be about all I can locate.
Does anyone on this forum have the tabs installed, and if so, do they actually work and would you be willing to take some detailed measurements? Length, width, thickness, type of material (aluminum or steel), bolt/screw hole placement, bolt sizes, and any other particulars that you could share. I have access to someone who can build them, I just don't know what to tell them to build.
THANKS!!!
THANKS!!!
