Andygtx2000
Guys I need help please it’s a 2000 seadoo gtx 951 with the carbs when I push the start button the starter sounds like it wants to start but it gets stuck right away.
Will you watch this video I just made on the issue? I feel like it’s better explained visuallyAlso check that your ground connection from the negative of battery to the bottom of the motor is tight, it should not be connected to the air box bracket that also secures the rear of the starter.
Nope, haven’t replaced the starter. That was the original one. bought a new one from sea doo. But haven’t installed it yet. Are you saying those aren’t good?
I did replace the solenoid tho. And I removed the oem starterI didn't have the patience to really watch the entire 4:36 minute video, but did you say the 'original starter' at 3:02 was replaced? with what? aftermarket by chance? if so that's your problem.
Aftermarket starters are crap, they never hold up long, get a worn out OEM and rebuild it, you'll be better off.
Well, I went to my local motor sports store and they are a dealer also. That’s where I got it from. I’m sure they got it from sea doo thoNo, OEM is good, you bought it new from a Seadoo dealer? Question, can you turn the engine by hand at the PTO? Could be a starter issue, sounds like it's not engaging the flywheel properly.
The problem On the first part of the video is with the oem starter. Then I removed that one and tried putting the new one in but was having issues. I’m going to go ahead and remove the carbs since I need them rebuilt anyway and that’ll give me more room to work with. Do you think that’ll solve it?Ok, it's becoming confusing, in post #3 you haven't replaced the starter, but you did remove it. Now you have the problem as described in the video. I'd double check that it's seated good when you put it back on.
I tried putting it in but i can’t get it to go in all the way. It goes in to about a quarter inch away and it stops. I don’t want to bang in itOk, so you did install the new one, but you had issues? what kind of issues? No, I don't think rebuilding the carbs will solve your issue of the starter engagement, though I think rebuilding the carbs is good idea anyway.
I am going to buy a rebuild kit and rebuild the oem one and have it on the sideThis is your issue, it needs to be seated all the way. If the engine turns by hand at the PTO and the starter is good and it's seated all the way that should fix it.
Keep the old OEM starter, encase the new starter goes, I have a feeling you may have an aftermarket. OEM new if you can find it, they'll run close to $250 - $300.
Okay see glad I asked lol iFor the life of God, and I am non religious, DO NOT remove that pipe, or you will be in jet ski hell! There are many possibilities! Here are a few...If you need to remove the starter again,then remove the air box, and or remove the carbs and lay them on rags at the bottom of the hull. Make sure you remove the ground from the battery first. Then you will just need to remove the bracket at the back of the starter. Then you will be able to Jiggle/ wiggle out the starter again. You can check that the positive able is secure. You should not have to bang the starter in. I assume that you have checked that the cylinders are not hydro locked, full of water. Remove the gray pto cover, remove your plugs, and see if you can rotate the pto/ crank by hand.
What would my next step be? I tried it and it seems like I’m hydro lockedFor the life of God, and I am non religious, DO NOT remove that pipe, or you will be in jet ski hell! There are many possibilities! Here are a few...If you need to remove the starter again,then remove the air box, and or remove the carbs and lay them on rags at the bottom of the hull. Make sure you remove the ground from the battery first. Then you will just need to remove the bracket at the back of the starter. Then you will be able to Jiggle/ wiggle out the starter again. You can check that the positive able is secure. You should not have to bang the starter in. I assume that you have checked that the cylinders are not hydro locked, full of water. Remove the gray pto cover, remove your plugs, and see if you can rotate the pto/ crank by hand.
Hydrolocked means that the cylinders are filled with a fluid like water or fuel. IF you take the plugs out and it still will not turn over you are not hydrolocked as the fluid would just come out of the plug holes.I think I’m hydro locked. I took the spark plugs out and I can’t spin it by hand
