I've rebuilt the carbs to factory specs
Well if it wouldn't turn over with plugs in, tells me battery is low from the start.I agree. It sounds weak to me as well. That’s also a lot of fuel coming out, but if you’ve been cranking on it long enough to discharge the battery
That didn't look like fuel.If you didn't test the pop off, and seeing how much fuel is coming out of the spark plug holes then you may be flooding your engine.
eplacement kit for the rebuild was not oem
I connected a 1000CCA battery in series with a brand new battery in the ski. Still would not turn over the engine. Ended up that the brand new battery was bad. One can imagine all the things I checked and rechecked. The bad battery caught me completely by surprise.
