Ok, I need a little feedback here. I have an 05 RXT with a Riva stageIII and an on going overheat issue. This seems to involve only the exhaust cooling system but has maxed my ability! First-overheat alarm was going off when at 65+ or occasionally on first acceleration (high). I took apart j pipe, removed and clr'd intercooler, and fully backflushed entire system hose by hose, and all is clear, water is flowing well. Took unit out and almost melted it due to high heat sensor not being connected (and not acknowledging red light on dash), this melted several components including the waterbox rubber insulating cover due to the excessive overheat. After removal of waterbox and inspection- noticed that the mid plate and baffle plates were blasted apart and or bent completly out of the way exposing the bottom of the can. There was a large piece of the metal plate loose and bouncing around inside, which led me to believe that this may have been causing the intermitent overheat issue due to its movement and possible ability to cover and restrict the water flowing out of the box. I have Installed new waterbox, sensor,and misc. other components and took to lake. Everything works, but I am still getting a high heat alert if I WOT for more than a couple of seconds.
Do I need to enlarge the small holes in the bottom of the J pipe? Maybe slightly restrict the outflow of the hose at the top of the J pipe to keep more water flowing to the waterbox instead of flowing out the backflush tube? Something else?
ANY ADVICE WOULD BE APPRECATED!
