DJ Dome
Hey guys. I been working on my 1994 seadoo xp all summer trying to fix the carburetor/fuel problems. I followed everything to a T on this site. I rebuilt my carbs, changed all my fuel lines, changed check valves, brand new fuel filter canaster, new fuel selector, new plugs, new rectifier, new starter solenoid, cut back wires, pop off test, compression, new battery, and my low speed adjusters are at 1 1/4 out on each carb high speed at 0. It used to idle fine and start up fine before I did all this work but went no where in the water. Now I can get it to only start on choke while feathering gas a little then it stalls. It won't just adjust to an idle like when I first rebuilt the carbs. It's hard starting n keeping it running. It's so frustrating. I killed my battery today just trying to get it to idle, out the water. I would think this ski should run so good changing everything. It ran so good before the rebuild out the water just had the problem that they all explain. I tackled all tasks. Something has to be wrong. All the lines are routed correct. I just don't get it!!! CAN YALLL PLEASE HELP ME!!!!
