jskillz28 Active Member Jul 31, 2018 #1 Going from WOT to idle, the port motor will hang up at about 2kish and after a few second will drop down to 1500. Is there anything to worry about?
Dr Honda Well-Known Member Aug 7, 2018 #2 It may be a bit lean. I would open the low screw just a little on both carbs. OR... the cables are hanging a little. Make sure that the carbs close, and sit on the idle set screw, and that the cables have some slack at idle.
jskillz28 Active Member Aug 10, 2018 #3 Appreciate the feedback! Ill tune the carb and see if changes.
