standbybrad
Hi All,
New here but loving this website, it is a great resource.
I just bought a 2000 RX this winter and im trying to get it ready for the season.
First test run on the lake i was only running in one cylinder and it was bogging when i would try and accelerate. If i worked the throttle i could get it to suddenly take off on both cylinders but shortly after it would bog and stall.
Took the ski home and cleaned the carbs and put them back in... It is now firing in the first cylinder that was missing before. It is idling a bit better, and it will rev up much higher with the throttle but still seems rough. Before it was able to run on the second cylinder but not the first ( if i pulled plug wires and forced it to run on one ) Now it seems to be running stronger in the first and missing in the second.
I am thinking i am closer to running smooth and maybe i only need to play with the fuel mixtures and try and get the carbs to sync up a bit better. I am looking for peoples thoughts and experience on this. Am i right about probably only needing carb adjustments? This is my first seadoo.
As well i have already replaced the fuel and oil filters and changed my fuel lines out from the grey tempo ones; and i have syphoned the gas and replaced with new.
