My RFI isn't charging. I replaced the rectifier with a good one from another ski and that didn't fix it. I checked all the fuses, and they are fine.
I cleaned up my ground connections, still no luck.
What would you recommend my next step should be? How do you check the yellow wires from the stator? Most the posts seem that the rectifier is most common cause, but I have now tried two different ones and it didn't help.
Thanks
John
Thanks
John
