flyingarmy
This weekends task was to pull the old bunk board off the Shoreland'r trailer and replace the boards, carpet and add TACO Trailer Glyde Sticks. The lake is about an hour away so I ended up jacking up the boat using a screw jack and a 2X4. I placed the jack on the trailer axle with the board in between. (Picture #1) I slowly jacked the boat off until the pressure was off the bunk board. Next was the toughest part. I had already soaked the bolts/nuts with a penetrating lubricant to help get the rusted bolts off. Most of the nuts were too far gone and I had to use vice clamps and a lot of torque. Times like this I wish the bolt would have just broken! I pulled off the bunk board one at a time. Then used a small peice of 2X4 to place over the trailer mount, so if for some reason the jack failed it wouldn't punch a hole through the bottom. I used pressure treated 2X6s that were 8ft. I sawed off 4" since the carpet I bought was only 8ft long. I used the same mounting bracket, wire brushed and then painted with rustoleum. The outdoor carpet was from Lowe's and the TACO Glyde Sticks were from West marine. I used Loctight spray adhesive and Marine staples to put it all back together. They both look brand new. I'll found out this week what a difference the Glyde sticks make when launching and recovering. A definitely easy DIY job.
