Took the ski for a short run yesterday arvo and noticed the plugs where white. I've talked about it on the factory exhaust thread if you guys can have a look there and help so all the info about that stays on that post.
One the other hand i'm also having starter issues. When i press the starter i car here a slight grind noise and the starter turning but not the motor. Press a few times then the motor turned and we went for another blast. Came back turned it off and the same problem happened.
This time i went back home,It was doing the same thing so i tapped gently with a hammer on a bolt on the flywheel housing and again the engine started. So i quickly flushed it and turned if off.
So what could be causing this? Do these have a bendix drive behind the flywheel or is the problem on my starter?
thx
