I am interested in the top speed of 2008 and newer Speedster 150's with all engine choices, because people on this forum are reporting results that are all over the map. As best I can determine the 155hp normally aspirated Speedster 150 should do about 50mph. I am assuming the 215hp supercharged will do high 50's. According to the Sea Doo website, they spec 60mph for the 255hp supercharged (2009 and newer) -- here's a quote from Sea Doo's current website regarding the 255hp Speedster 150:
Jaw-dropping handling. Lightning-strike quickness. Even Mother Nature would stop and stare in awe. And with good reason. Flash across the water at 60 mph* (96.56 km/h) and crank the wheel toward your next stop. No problem. This boat and the water are inseparable. With room for three friends and the ability to go from 0 to 30 mph (48.28 km/h) in 2.8 seconds*, you won’t want to leave either.
*With High Output engine.
I recently ran into a guy at my boat launch who had two new RXT's, one 215hp supercharged, the other 255hp supercharged, otherwise identical. I asked him what the performance differences were between the two. He told me the 255hp was only 2 or 3 mph faster, but that it gets up there quite a bit quicker. Assuming the same is true for the boats, which is logical, it seems as though the 255hp gives you better acceleration but not much more top speed than the 215hp.
I recently test drove a 2008 Speedster 150 with the 215hp supercharged engine. The fastest it would do according to the speedometer was 48mph. And the acceleration wasn't very impressive either. My 125hp Kawasaki STX-12F jet ski would eat it for lunch and I was not expecting that to be the case -- yes the Speedster is heavier but it also has almost twice the horsepower. Note in the above quote that Sea Doo also specs the 255hp Speedsters as doing 0-30mph in 2.8 seconds -- plenty fast for me, but how does that compare to the 155hp and 215hp models?
The guy whose boat I test drove said his boat was basically brand new, had only been used a couple of times and only had an hour or two on it. From the looks of both the boat and trailer I believe him, but the acceleration and indicated speed made me skeptical about the boat. In addition, the hour meter was at "1" when we started out, returned to "0" and never exceeded "1" hour on the display even though we were out for over an hour. I subsequently read somewhere on here that these boats had hour meter problems requiring a software update. So who knows what the actual hours were, or whether the speedometer was accurate. Even though the boat was in brand new condition, I decided to pass on it because of those two issues.
The Speedster is exactly what I'm looking for -- jet ski performance and handling but in a small boat rather than a ski. The problem with a jet ski is that you're on it, not in it. Taking a friend isn't much fun when they're relegated to being the "bitch" on the back. With the Speedster everyone can enjoy it and there is room to move around rather than being confined to sitting on it. You also don't have to constantly wear an uncomfortable and hot life vest and get a striped tan.
It's unfortunate that Only Sea Doo makes a small jet boat like this. Being detail oriented, in my opinion the build quality and fit and finish of the Japanese products, Kawasaki and Yamaha, are far better than Sea Doo. I also don't know much about the Rotax engine other than horror stories about the supercharger ceramic washers. I do know you can depend on a Kawasaki or Yamaha engine -- typical first class Japanese engineering and quality.
But that being the case, the Speedster is the only show in town, and it's design is very clever -- I want one, but if the 215hp model I drove is representative, then I might as well get a 155hp and not have to deal with supercharger issues, because the 215 I drove performed as I would have expected the 155 to perform, and I'm not especially satisfied with that low level of performance. If I want higher performance it appears the 255hp is the only option, unless of course there was some kind of problem with the 215 I drove. But it genuinely appeared to be almost brand new, and was doing 7800 rpm maxed out, so it appears it was performing properly and the engine was nice and smooth, no fouled plugs, bent impeller vibration or anything like that -- it was in showroom condition. If the speedometer was simply inaccurate, it seems to be a widespread issue and I don't know why Sea Doo can't make instruments that are reasonably accurate. If I recall it used the same type of wheel sensor on the transom as my Kawasaki and the Kawi is extremely accurate, having compared the indicated speed to a GPS.
So to summarize my overly long post (sorry about that) I am interested in what a Speester 150 with the 215hp engine (as well as the 155 and 255) will actually do in terms of top speed and rpm, and acceleration, so as I shop I know what the actual performance perameters are and I have a reference point for comparison if I'm able to test drive it, which isn't always easy to arrange.
Two final things. I'm in California. Boats here have a factory sticker on them indicating the California Air Resources Board emissions level of the craft. Three stars is "ultra low emissions" and two stars is "very low emissions". According to Sea Doo's own specifications, the 2008 and newer Speedster 150 with either the 155hp or the 215hp supecharged, are BOTH supposed to be three star certified, as is the 255hp supercharged, but I have seen three of them now with 215hp and one or two 155hp, one a brand new 215hp 2008 Speedster in a dealer showroom, and all three had two star stickers on them, not three star. I even checked the VIN numbers on all three to confirm they were in fact 2008 models. So the badging on the boats does not match Sea Doo's own specs. A minor point perhaps, but indicative of the kind of inconsistency I'm seeing with Sea Doo products.
Lastly, I have seen two different threads on here where people claim they have purchased brand new 215hp supercharged Speedsters and then discovered that they were not supercharged. I believe one claimed that Sea Doo replaced the boat after four or five months of haggling. I simply cannot believe that the Sea Doo factory would make such an error. This does not seem credible to me and I do not believe this is true. It's hard to imagine how they would be able to stay in business. However, if it turns out that it is in fact accurate, then I don't think I would ever buy a Sea Doo product because that kind of slop would be indicative of a company that makes crap. So please tell me it ain't so.
Perhaps someone with Sea Doo expertise can respond to some of my questions.
Thanks
Thanks
