Shop Discount Sea-Doo Parts
RAVE vavle broken
glouis1723
Messages
7
Location
Tarpon Springs, FL
Water Crafts
1997 Sea-Doo GTX 787
1997 Sea-Doo GTI 718
i have a 1997 gtx and the rave valve was shooting oil all over the place so i took it apart and every inch of it was covered in oil so i get down to the last of it and the thing attach to screw or what ever its called was broken of in side the engine. I'm just wondering if this is anything serious? Thanks
boatmonkey82
Messages
104
Location
nc
Water Crafts
98 palm beach 225 johnson
3/4 mpg
95 trophy 24ft 225 johnson
65 galaxy 85 merc
umm , thats not good . the oil or black crud all over the valve is normal , its due to running cheap oil , run a high grade oil and it will drasticly reduce this problem . your rave valve should look like this -----}}} if it looks like
------ and the }}}} is broke off in the engine then you need to check for piston damage by looking thru the rave port and turn the motor over any gouges or deep scratches will need to be fixed , you also need to check your compression , if all looks good then you lucked out big time and i would replace both rave valves and rebuild the diaphrams with them . here is a pic of a broken one http://i25.tinypic.com/20hq15z.jpg and here is a good onehttp://www.powersportspartsplus.com/catalog/ccc1_1_59_1_thumb.JPG
Messages
52
Location
Michigan
Water Crafts
96xp Limited mod
95 kawi 750ss
91 Kawi 440/550 Limited mod
Usually you see that problem with the early 787 rave valves like the one's that came in the 95 xp limited. I would go with the newer slotted rave valves when you do replace the top end.
glouis1723
Messages
7
Location
Tarpon Springs, FL
Water Crafts
Thanks
Thanks for the help i decided to get a whole new engine any tips that i could use to keep this from happening again?
glouis1723
Messages
7
Location
Tarpon Springs, FL
Water Crafts
we rebuilt the carbs and i dont know extact if we got the slotted rave vavles sbt has them but it says that there stock rave vavle so are they the new ones?
kustomkarl
Moderator
Moderator
Premium Member
Messages
11,229
Location
Sunny S.W. coast of Englewood, Florida
Water Crafts
1996 Chris Craft 26' Cruiser, Kawasaki 440 Superstock, 550 Mod., 2008 200Speedster 310 Hp
I'm sure that the rave valves that sbt sent you will be ok. There is a updated version that have slots in them but both will work ok.
Karl
SPONSORED LINKS
Usergroup
