Hi Experts,
This all started with it not starting. Thought battery, then solenoid, then starter. I took the starter apart and to my delight noticed the brushes were stuck up. I fixed, then it tried to crank but stoped. It sounded like hydrolock. So I took out the plugs and it cranked, no water. Then put plugs in no crank. I figured the starter was still bad, so I replaced the starter.
New starter same thing. This time I tried to start with loose plugs and it fired, I still had to give it gas to start it though. I heard something funny when it was trying to start sounded like electric spark. Well I started looking into maybe the jet pump being stuck. Oh yeah did a compression test 150lb each side. I moved the crank by hand and started hearing that sound again but slow. It is sounding like something in the lower end. sounds like bearing falling. The thing I can't understand is when I started it, I tightend down the plugs and was really reving and it didn't break? I took the motor out and looked in the rave but nothing looks banged up. Any Ideas, I guess I will start to take off the cylinders. One more thing. The magneto was cover in rust so I am thinking that is why it wouldn't start? Or the crank?
Thanks Matt
Thanks Matt
