Your intercooler is external not the same as the 215hp intercooler that is mounted in engine, your intercooler is described in your owners manual what to do for storage, they just want you to pull both inlet and outlet airside hoses off and small bleeder hose at top and turn down so airside in pointing down and leave like that for 30 minutes is what they say to drain any water out, I was just going to pull intercooler out altogether and store in a dry place. The flush connector they show in the owners manual shows a typical flush connector that happens to be on the right side of pump in the manual, but it is the same thing as ours that is on the left side of pump, I blew out mine from the flush connector with compressed air, just to see how much I would get out and I only got about 3 ounces of water out until no more came out, maybe that is all that was in there, not sure, but after doing that and thinking that there is no more water in there, even after starting up the motor to see if exhaust pressure would push anymore out, which it didn't, I pushed in 4 gallons of propylene glycol with a submersible pump from a bucket into my flush connector with the boat started up first until I could see the fluid coming out of jet pump and exhaust, I just figured on putting in some antifreeze that had inhibitors and that is good for aluminum parts to keep any water that still might be in there protected from corrosion, blowing it out with compressed air I think would take care of the water that may be in the intercooler since the intercooler water side seems like it would be self draining because how it is mounted high up over the engine and jet pump, you could also pull the hose off the bottom of the exhaust manifold to drain it the manifold
