abethebabe
Rebuilt my 140mm pump, had dealer press bearings in and install my aftermarket wear ring. Can't torque the new swirl impeller down as I'm getting a gap variance of .005 to .032 at the blade tip in just a quarter turn of the impeller. Hoping it is a bad wear ring as it is not uniform in it's thickness where it bottoms into pump housing. Pretty bummed out, long weekend and all. Also tried the oem impeller, same gap. Could the plastic pump housing be this warped?
Mike
Mike
