Basically join the forum to ask these questions, it's my first time having a spark and literally after an hour on the odometer it chewed up a rock causing damage to a few things. Yes I own other jetskis just not seadoos in particular.
There's this plastic tube that comes out behind the jetski where the impeller housing is and broke a chunk. How do I replace this? How hard is it? What is it for? How important is it?
Also, when the jetski chewed up the rock it broke the entire wear ring, would this cause the jetski to not move at all? The impeller does not look really damaged, my Yamaha has 200 plus hours and the impeller on the seadoo is not damaged as much as my Yamaha would look.
Would they major factor be that the wear ring was completely missing?
Attached some pictures of the tubing that broke, I believe it's called the water fitting tube. Part number 271001818
