I'm hoping somebody can steer me in the right direction, it's June and I've yet to be on the water!
Summary:
Freshly rebuilt carbs this spring
stock fuel lines were replaced 5 years ago and new ones show no sign of breaking down
Reason the carbs were rebuilt was last year I would top out at 6k - turns out the barb on the carb pulse line was cracked.
I also pulled the engine and fuel tank this spring - gas can nozzle had fallen in the tank and I decided to get it out and clean it up.
I've double checked connections and how the lines are run - 99.9% sure everything is correct.
I can run the starter all day and get no fuel into the carb - won't even fill up the filter bowl.
However, if I pull the fuel line going into the carb and syphon it, I can pull gas from the tank, through the filter and all the way up the line.
I don't have a pressure test kit, but when I pulled the gas line off the carb and blew into it, I got air flow and a whistling sound (closest way to describe it is Rudolphs nose in the old cartoon).
The engine will run great by putting a bit of gas in the carbs, but once that burns off, it dies.
The only change to the set-up seems to be that the end plate on the carb is new (to replace where the broken barb was) - it must be off a slightly different carb as the old one said pulse and the new plate has fuel stamped on it, but looks exactly the same.
Would really appreciate any advice available - I've spent countless hours on this with no progress.
Thanks!
Summary:
Thanks!
