Parkerized ( Rust Proofed ) the trailer coupler
tresvatos1
image.jpgJust something I did today to cure this problem. Any hunters or weapon enthusiast have probably heard of parkerizing a gun barrel. It is a chemical process that makes the gun barrel not only not rust, but cling onto any oil like based molecules in the air. This provides a constant lubrictating effect . I had the materials and set up for doing gun barrels so I decided to do the trailer hitch coupler that was rusting and getting to be an eye sore! At least this will be one less thing to have to maintain on the trailer. now I'm doing my winch levers and gears and the hooks on the Speedsters tie down rear straps . Just something to do since I had the stuff! Lolimage.jpg
That's cool! You might not know it but you can buy a ball that has the top 1/3 made from plastic or Teflon. No grease required.
Like this rapid hitch ball. It's just a cap or coating
https://www.andersenhitches.com/Products/3453--2-greaseless-single-alumiball.aspx
Maybe not a bad idea, will look into doing that too.
I use this one, (Reese 74307) without grease that sucks up the sand and grit like a neodymium magnet, the ball rotates and just a few occasional drops of ATF to dissolve and clean out road grit and wipe off, keeps it all working well.
Pretty good ideas ! I went ahead and parkerized my trailer ball too + all metal hooks, chains, and strap clamps just for the added protection.
