wdemaster
Hello Everyone!
I have to apologize if I looked over a thread that contained this question and missed it. I looked fairly extensively and didn't happen across anything.
I just bought a 2004 Speedster 200 and got it out on the water this weekend. It was amazing! Well, for the most part. Something like every 10-20 minutes, the port check engine light would go off along with a beep. That engines RPM's would drop approximately 2000 but keep running. It didn't seem to matter what RPM the engine was at before it went off, it would always drop about the same number. I checked the physical oil level, and all was well. I could pull the lanyard, reinstall it, restart the engines and everything would work again for the next 10-20 minutes, as long as I was running above an idle. All of the times it happened, was running above 4000 RMP's. This happened 5 times total, the second time, both check engine lights came on. None of the other error lights came on.
I had it to a dealership today to have it checked out. The computer returned something about the "Oil Shut-off Solenoid" being bad. The service writer told me they had a test they did, and each solenoid failed every time. He said they were EXTREMELY difficult to replace because of their location. However, I feel they would be fairly easily accessed if the under-seat tubs were pulled up. He quoted me $870 for the repair after labor and that the parts were $270/ea.
So here is my actual question. Given that they are designed to prevent oil from getting pumped out of the engine in the event of a roll over [what the dealership told me], how detrimental is it to the engine if they are not dealt with and keep tripping the check engine light? You know, besides the annoyance factor....
Thanks for the help!
-Wes
-Wes
