I have a 93 GTS and one day riding when I got done there was a lot of oil in the hull, stopped riding for the weekend, cleaned the hull out when I got home and found where the leak is. It is the seal between the cylinder and the crank case on the carb side back cylinder.
I have a junk motor that I got for free to tear apart and figure things out and not worry to much if I break anything.
Does anyone know how this seal might start leaking?
If I purchase a top end rebuild kit and install it if it will fix the problem?
Thank you,
Craig
Thank you,
Craig
