On my 97 GTX with the Rotax 787, I just installed the block off plate to the new motor. I cannot find a clear-cut answer on what to do with the remaining oil lines. I did what I thought to be right but I think I did something wrong. Rather then keeping the tank lines hooked to the motor, I removed them and blocked off the oil tank. I then filled the crankcase with a little oil, and connected a piece of the oil line hose on both sides of the crankcase fittings to tie/block them together. Is this ok or did I not do it correctly?
