Blaked70
Hey everyone I'm new to this forum so I'm sorry if I'm not upto scratch with the layout etc!
I'm having some trouble with my 1999 gti seadoo 720cc I bought a new battery and plugs yesterday as my other ones were stuffed anyway...however when the ski is running and I take the negative terminal off the battery it shuts down right away! From my common sense (might not be common ) the ski should keep running, correct?? So i chucked a volt meter on the two yellow wires coming off the rectifier at idle and had 11-12 coming through and increased if I rev it but that seems really low. I have 12.7v coming through the red and black out of the rectifier which I believe should sit around 14volts would this mean my regulator/ rectifier is causing the problem. Constant 12.5volt coming off battery terminals at idle
Any help or opinions would be hugely appreciated!
Regards, Blake
Regards, Blake
