No water pumping through
aaronsmalley
In my 93 XP, I have water coming out the "pisser" when hooked up to the hose in the driveway. When I put it in the water, no water comes out and then a couple of minutes into riding, the beeper goes off. Can anyone tell me what to check? Could this be a jet pump problem?
Thanks in advance
On the hose it is actually reverse flushing the system. So if you have a blockage it might not show up on the hose.
I suggest pulling each hose one at a time and blowing compressed air through each one.
what he said above
you should have 2 pissers active
note that the connections to the exhaust system have orifices to regulate water flow and tend to get crudded up, do not get the fittings mixed up
